how to keep "Z" bars from moving
Old Sep 2, 2014 | 04:00 PM
JRK5892's Avatar
JRK5892
cut a small piece of emery cloth, put it under the riser clamp, done and done, i do it almost every time i do bars for customers
Old Sep 2, 2014 | 04:10 PM
Misbehaven's Avatar
Misbehaven
Dry wall sanding screen works great. Cut some strips and wrap around your bars at he clamp area.
Old Sep 2, 2014 | 07:09 PM
Bklim's Avatar
Bklim
I had similar problems with my 12" apes on my '07 FXD, they were always tweeking. I found an odd fix in my local Home Depot. In the area near the fastners, I found these flat S.S. double knurled strips, they are about 1"x2" . They are made for cutting up and inserting into stripped holes where both sides will grab (Screw and hole wall). I used the entire strip on the bottom of each riser under the bar and followed the H-D specs for torquing the riser bolt clamps. The rough side of these strips grabbed the riser and the bar and it's not moved once all summer. Wish I could remember the name or brand but they did work. You don't have to worry about the wires in your bars with this fix. Good Luck !
Old Sep 3, 2014 | 04:29 AM
loopie's Avatar
loopie
if you do that I wouldn't even let you touch a pushbike, are you for real ,,,
im sure the insurance company/lawyer will sue your **** when theres a issue...:icon_ smash:
Old Sep 3, 2014 | 04:55 AM
Deadhead77's Avatar
Deadhead77
Seriously? I mean really? You people hating on this subject and the people providing useful info on how to fix it. JRK5892 knows what he's doing...just ask around. It's obvious the people running their mouths have never run a bike with tall bars. High dollar or cheap bars can both have a tendency to move in the risers whether knurled or not. I have used skateboard grip tape between the bars and risers on several different bikes with great results.
Old Sep 4, 2014 | 10:10 AM
INJEKTER's Avatar
INJEKTER
MY post is in reference to buying some cheap sub par online Chinese part... like a bar that is supposed to have a 1" OD but is really 3/4..... i wouldn't waste my time with that.... that's all i meant....otherwise, fixes for a specked out part sound great....
Old Sep 4, 2014 | 10:29 AM
Deadhead77's Avatar
Deadhead77
It's all good bro! I'm with ya! Sorry to vent but the ridiculous comment from the loopie Aussie got me fired up.
Old Sep 4, 2014 | 10:48 AM
Ninety8NeonACR's Avatar
Ninety8NeonACR
I have 16" apes and had to use emery cloth on my knurled bars. I cut 2 strips almost long enough to wrap around the bars and folded them in half sideways so there was grit on both sides, wrapped them around the bars and installed the top clamp. When you run taller bars the amount of torque on them will move them without doing something like this.
Old Sep 4, 2014 | 11:23 AM
CACruiserHD's Avatar
CACruiserHD
If I ever NEED to use emery cloth to hold something in place I will put a for sale sign on it the next day.
Old Sep 4, 2014 | 11:56 AM
Deadhead77's Avatar
Deadhead77
LOL! It's really not as bad as it sounds. I give up on this thread, I'm going shopping for taller bars and more emery cloth.
