lowering kickstands?
Old Sep 15, 2014 | 12:29 PM
Simplespeed's Avatar
Simplespeed
Default lowering kickstands?
Can someone recommend a good quality lowering kickstand? I have the burly slammer kit and if the the wind blows my bike might fall over. Id like to prevent that lol. Thanks guys.
Old Sep 15, 2014 | 12:51 PM
DIRERIDE's Avatar
DIRERIDE
i went with a simple -1 kickstand from j and p cycles.
super easy install, if you have a second pair of hands
100% function, never worried about my bike tipping over.
http://www.jpcycles.com/product/5300345
Old Sep 15, 2014 | 01:00 PM
JRK5892's Avatar
JRK5892
you can shave the tab on the stock stand where it makes contact in the keeper that is an easy way to do it... you can also go with a lower kickstand
here is a stock stand on the right with a shaved keeper tab, and a -1 lower kickstand, I took about 1/8 off the tab, and got more of a lean. i was just not pleased with how the throw of the stand worked out when trying to put the kickstand down. I got a stand off ebay for like $20 that was -1, works great!
did have to move my frame bump so the stand was not on the frame
Old Sep 15, 2014 | 01:53 PM
CACruiserHD's Avatar
CACruiserHD
I had the same problem and ended up getting a black 1 inch shorter kickstand. Sits just right now. Putting my stock one on ebay.
Old Sep 15, 2014 | 02:13 PM
Simplespeed
Alright -1 in black sounds good. Thanks guys, i knew yall would know.
Old Sep 15, 2014 | 02:36 PM
BigDogIdaho's Avatar
BigDogIdaho
Is the -1" kickstand actually a different length or just a different bend/angle? Has anyone else had troubles or didn't like the shaving of the tab?
Of course if you can find the same deal as Joe, you might as well go for that!
Old Sep 15, 2014 | 03:05 PM
CACruiserHD
its 1 inch shorter. Same bend as far as I can tell.
Old Sep 15, 2014 | 03:36 PM
JRK5892's Avatar
JRK5892
1" shorter, i have pics posted next to a stock one, you will have to move the bump stop and i also added a 1/2" rubber spacer to make it easeir to grab under the primary
Old Sep 15, 2014 | 06:12 PM
halfpint153's Avatar
halfpint153
I had the 1" shorter from ness , I still didn't like the way it sat. I ended up cutting and welding the stock one in to get it the way I wanted.
Old Sep 15, 2014 | 10:04 PM
Simplespeed
Right now i have to lean the bike to the right to get the kickstand all the way out, otherwise it hits the ground. Will a -1 do that?
