Help with wide glide conversion rotor spacers
Old Sep 17, 2014 | 05:37 AM
Dyna_Bagger85's Avatar
Dyna_Bagger85
Default Help with wide glide conversion rotor spacers
Since the Street Bob hub can be dual disc, I'd like to reuse it on my 23" wheel build and already do have the fat bob trees. I know they sell the wide glide conversion kits but I already have the axle and would need appropriate axle spacers and rotor spacers.
Anyone know where to get just the rotor spacers? All I've been coming across are the complete kits or spacers for 39/41mm front ends.
Old Sep 17, 2014 | 03:22 PM
Tat2u's Avatar
Tat2u
If you can't find any, Just go to your local engineering shop and tell them what you need, I machined my own in no time at all
Old Sep 17, 2014 | 06:07 PM
JRK5892's Avatar
JRK5892
i cut them on the mill, but first went to ace to get general spacers to find out just what size i needed, from there i milled them out, then they where welded to the mount... get your exact sizes and any machine shop can make these cheap! i wanted mine out of alum so they could be welded to the bracket
ace spacers
machined
welded and coated
Old Sep 17, 2014 | 06:13 PM
Dyna_Bagger85
ace spacers
machined
welded and coated
Joe I'm talking about the thick spacers that are bolted to the hub and the rotor attaches to it. Hawg Halters has a kit and they said they would sell both the axle spacers and rotor spacers. Here's the kit:http://hawghalters.com/triple-trees/.../prod_456.html
Old Sep 17, 2014 | 06:16 PM
JRK5892's Avatar
JRK5892
ah ok ok, so you need the complete piece. something like that would not be a simple spacer on each bolt you would need the full contact. that would be $$$
Old Sep 17, 2014 | 06:18 PM
Dyna_Bagger85
Man if 13" rotors weren't so damn pricey I'd go that route so I'd still have a single disc to show off the 23" wheel
phog light
Jan 17, 2017 11:10 AM
canyoncritter
Jan 22, 2015 03:49 PM
Dyna_Bagger85
Oct 22, 2014 06:34 AM
chrishelmkamp
Jun 5, 2013 04:57 PM
JCK
Feb 26, 2010 08:19 PM
