Gone Thru my 3rd Coil!
Old Mar 14, 2015 | 11:25 PM
robertlee's Avatar
robertlee
1st Gear
Default Gone Thru my 3rd Coil!
'95 stock factory Evo motor mounted in an early frame. When I first got the bike, coil failed. Put in a new dual fire coil. Good. Rewired the bike. Good Within a few rides, coil failed. One hole gone, dead as I remember. Bought a new Andrews red coil. Installed it good. Bought this motor, different electronic ignition, new, and used the 3 ohm Andrews coil. All good until 2 weeks ago rode about ten miles. Stared to get a backfire. at idle. Made it home. Today. New plugs, cleaned e ignition components, drained and changed gas, cleaned jets, fired up great. Rode for 8 miles to test. When I returned, misfire, just like before. So that's the 3rd coil. I ordered a 5 ohm and I have a points setup here on the table. Going to install it just for kicks. I have never had 3 coils go in such a short time. Can't figure why these are failing. Last one, one hole just dead. Anybody had these issues?
Old Mar 18, 2015 | 11:09 PM
okcjetmech's Avatar
okcjetmech
Are you getting good grounds from coil to frame to motor? With an earlier frame you might be missing a ground and causing them to burn out. Just throwing an Idea out there.....
texashillcountry
EVO
39
May 12, 2017 02:14 PM
junglejoe
EVO
69
Dec 14, 2015 06:25 AM
astark
EVO
Aug 2, 2013 12:29 AM
RidemyEVO
EVO
11
Jun 8, 2011 03:03 AM
jizquie560@aol.com
Aug 12, 2009 02:19 PM
