Headlight Bulb Suggestions
Old Sep 15, 2005 | 08:44 PM
HDF Tech's Avatar
HDF Tech
Default Headlight Bulb Suggestions
A good alternative to the stock bulb is the "Xenon BriteLite" from the NAPA parts store for a headlight that is much brighter than stock. NAPA will probably have to order it for you (part number BP1260/H4BL), but it is a direct replacement for the stock H-4 bulb.
The Sealed Beam Headlight on the '02 Fat Boy is just dim - no other word for it. Replace it with the same set up used in the rest of the Harleys - an H-4 bulb and reflector - cheap! JC Whitney sells item number "13zx9314a, H4 Halogen Headlight, Round MC" for $16.95, this kit includes the H-4 bulb, rubber boot to seal the bulb and the reflector. It is plug and play, remove the sealed beam light and install this kit.
Old Dec 19, 2008 | 07:52 AM
zell90r94's Avatar
zell90r94
Default Adjure headlights
Do you know if the Adjure 7" headlight with the H4 bulb would be a simple replacement for my stock 02' fatboy headlight? The stock headlight sucks.
Thanks
Whiskyjock
Jul 27, 2019 06:41 AM
WideBoy04
Apr 18, 2010 12:20 PM
bluedemon06
Apr 13, 2009 05:06 PM
thomasf59
Apr 6, 2008 09:38 AM
