Aftermarket Electrical Harness Problem - Help!
Old Mar 28, 2015 | 04:37 PM
extremeshot's Avatar
extremeshot
Default Aftermarket Electrical Harness Problem - Help!
I installed a Thunderheart Micro Harness with the Stand Alone Ignition System.
The bike runs great but I have a couple problems with the Hi-Beam that I need help solving. I've tried several things myself but I'm not having any luck.
Problem 1: The Hi-Beam indicator light is reversed and is on for Low Beam, and off for Hi-Beam. However, the switch is installed correctly in that Hi beam comes on when the switch shows Hi-Beam.
Problem 2: The rear tail light completely turns OFF when I switch to Hi-Beam.
To clarify, when I move the switch to Hi-Beam, my front head light correctly turns on the Hi Beam, but the Hi-Beam indicator light is OFF, and the Rear tail light is completely dead.
Then when I move the switch to Lo-Beam, my front head light correctly goes back to the Lo Beam, but the Hi-Beam indicator light is ON, and the Rear tail light turns back on and works correctly when pushing on the brake.
I have totally racked my brain on this. If you have any suggestions on what could be wrong I would be extremely grateful!
Thanks!!
D
Old Mar 29, 2015 | 07:58 AM
nhrider1's Avatar
nhrider1
Thanks!!
D
Don't know which model you have, but it sounds like the high beam indicator and the brake light switch have been reversed in the harness.
Statefarm-outlaw
General Topics/Tech Tips
Jul 6, 2017 11:13 PM
ekoehler4567
Jul 24, 2016 01:01 PM
dwe.61
39
Nov 27, 2015 12:03 PM
nchogfan
Dec 2, 2013 08:08 AM
jswhitex
Ironhead
30
Jun 2, 2009 11:14 AM
