Harley Engine Guard Lights
Old Mar 30, 2015 | 07:39 PM
wam6187's Avatar
wam6187
Default Harley Engine Guard Lights
I have a set of these - http://www.harley-davidson.com/store...nted-fog-lamps and would like to wire them in direct. The relay that comes with the kit keeps getting corroded and consequently makes the lights stop working. With that said, why couldn't I do away with the relay and wire these direct (using the ACC switch)?
Thanks ahead
Bill
Old Mar 31, 2015 | 07:02 AM
grbrown's Avatar
grbrown
Bill, I have had the same lights for about five years now and they work fine. If your relay keeps failing that suggests it is in an exposed position. As for doing away with it those lights take quite a bit of power and it wouldn't be wise IMHO. The relay is there to protect your harness. If you wire through the ACC switch that will be live with all the power going to the lights! Check the location of the relay and see if you can move it to somewhere more friendly for it.
Old Mar 31, 2015 | 07:42 AM
J929626's Avatar
J929626
HELLA, and others, also make waterproof relays and connectors if you can't find a more suitable location.
Old Mar 31, 2015 | 09:13 AM
wam6187's Avatar
wam6187
Thanks for the feedback guys. I forgot to mention, I am in the process of also hiding the wires in the engine guard so I will see what options there are to relocate the relay. At present it is under the seat and everytime the bike gets wet so does the relay...
rebbe18
Nov 29, 2013 11:33 AM
TRIGG321
May 24, 2010 04:44 PM
Jukebox
Feb 19, 2009 06:20 PM
jcbpa
Sep 3, 2008 10:01 PM
52edub
Nov 10, 2007 04:35 PM
