HD Fog Lights Don't Work???
Old Sep 1, 2008 | 06:45 PM
jcbpa's Avatar
jcbpa
Question HD Fog Lights Don't Work???
Okay, I had the dealer install the fog lights when the bike was in for some work. He did a great job hiding the wires and insulating them going through the crash bars and wiring to the left toggle switch. All of a sudden they stopped working. I checked the fuse today and pulled one of the lights to check the bulb which was fine. Tightened the ground in the light on one side... did not remove the other which I will do next and check. Any thoughts how to find the problem?
Old Sep 1, 2008 | 06:52 PM
Badbagger09's Avatar
Badbagger09
I hope he internally wired it without issue. I am getting fog lights put on my 09 SG this week and am thinking of putting the wires inside the engine guard. Hope you find the problem.
Ride Safe
Old Sep 1, 2008 | 07:08 PM
kurtlange's Avatar
kurtlange
take it back to the dealer?? they did something wrong...
Old Sep 1, 2008 | 07:30 PM
jcbpa's Avatar
jcbpa
Yeah, that's what I will do, unless I can track it down. I don't want the bike down during this time of year.... Need some other suggestions.
Old Sep 1, 2008 | 07:32 PM
Tinkermc's Avatar
Tinkermc
if you have a good bulb, positive electricity, negative ground, and a good switch then you must have light.
Old Sep 1, 2008 | 07:56 PM
jcbpa's Avatar
jcbpa
Okay, I agree, now how do you test?
The bulbs appear good...
Old Sep 1, 2008 | 09:22 PM
04ctd's Avatar
04ctd
find a buddy with a multi meter, and start tracing voltage.
hit the socket / base inside the bulb socket, and check ground and Voltage there
maybe push a needle into the wires going into the guard, and check for voltage/ground there.
Old Sep 1, 2008 | 09:25 PM
04ctd's Avatar
04ctd
use a battery charger to test bulbs, or check for continuity across bulb leads.
Old Sep 2, 2008 | 07:21 PM
jcbpa's Avatar
jcbpa
Thanks, I'm checking away, and found nothing yet...
Old Sep 3, 2008 | 08:18 PM
04ctd's Avatar
04ctd
shoot me a PM if you need to, and pm me your phone #
i will help you out, no problem
