possible ground issues
Old Apr 21, 2015 | 10:57 PM
sigbud's Avatar
sigbud
Stage I
Default possible ground issues
My speedometer brake light turn signals and horn stopped working suddenly all fuses are still good. Can anyone point me in right direction.
Old Apr 22, 2015 | 07:42 AM
cj741126's Avatar
cj741126
Start tracing wires. Depends on your bike and where they are but check to see if a plug came unplugged or rattled loose. Most wires & plugs are under the tank and near the neck but info on your bike would be helpful too. Could be something in your cluster as well.
Old Apr 22, 2015 | 09:54 PM
okcjetmech's Avatar
okcjetmech
It really helps to know what your ride is.
Old Apr 23, 2015 | 11:55 AM
enodrano's Avatar
enodrano
If it was a power going to ground issue you would most likely blow a fuse. Since it is multiple circuits at once I would check the main 40 amp fuse. Don't just use a fuse tester. Take it out and visually inspect the fuse.
All those things are on separate circuits so fuses are probably not the issue. I would check the main wire harness connectors. They may have pulled apart. Also, don't forget to check the connector that plugs into the speedometer.
Smash
Sep 29, 2015 05:19 PM
iRider
Electrical/Lighting/Alarm
Oct 2, 2014 09:12 AM
cmancini26
Nov 4, 2012 09:26 AM
1sikbob
Jul 17, 2010 02:57 PM
cwilson0823
May 11, 2008 08:37 PM
