Stator test number
Old May 14, 2015 | 04:30 PM
fiddledicksr's Avatar
fiddledicksr
Default Stator test number
2004 flhtci
been chasing a cutting out issue in my stereo system that has crop up when I installed a larger amp. we have eliminated the issue to the charging system i have replaced the Battery, regulator, inspected and clean all fuses, connectors and ground wires. I have run the test following test on the stator here are my values
idle 24 ACV
2000 48 ACV
3000 71 ACV
the stator tested good for no shorts on either wire using both with digital meter and light test.
Now here is the test i am not sure of, the resistance across the 2 stator wire. My readings are 0 and according to the book they should be .1 to .5 does this mean i need to replace stator
Old May 14, 2015 | 11:17 PM
Ed Ramberger's Avatar
Ed Ramberger
Originally Posted by fiddledicksr
2004 flhtci
idle 24 ACV
2000 48 ACV
3000 71 ACV
NO - 0 ohms is less than the allowable max. As long as they are not open. Open is bad.
Fitterwelder
May 17, 2019 07:10 PM
Diesel2
Jul 5, 2018 11:07 PM
extremeshot
Jan 16, 2014 09:25 PM
Bullys FLSTN
EVO
15
Jul 15, 2012 04:41 PM
jim h
EVO
Aug 28, 2010 04:06 AM
