Security Pass Code Reset '08
Old Jul 13, 2015 | 07:49 PM
mjonesjr84's Avatar
mjonesjr84
Default Security Pass Code Reset '08
I bought my '08 from my wife's great uncle. I've tried to enter the default security pass code via the turn signal switches. It always tells me that it is in correct. Is this something a dealer can reset?
Old Jul 14, 2015 | 10:04 AM
enodrano's Avatar
enodrano
Try the following:
With FOB present, cycle ignition switch IGNITION-OFF-IGNITION-OFF-IGNITION
Press left turn signal twice. (Turn Signals Flash 3 times.)
Press right turn signal once. (Current PIN should appear in the odometer.)
From there you can change the PIN or just see if it matches the one you're using. If you just see five dashes then no PIN is set. Refer to your owner's manual for instructions.
Old Jul 14, 2015 | 07:31 PM
mjonesjr84's Avatar
mjonesjr84
Originally Posted by enodrano
Try the following:
Worked perfectly. The code had been changed from the factory set codes in my owners manual.
Hero
Sep 13, 2023 02:15 PM
'10 Wide Glide
Jul 11, 2018 09:49 AM
rowle
Feb 24, 2013 01:45 PM
Dynalmadman
Aug 28, 2012 08:02 PM
0Nightster7
Jun 28, 2010 07:32 AM
