Battery Quick Connect(s)
Old Nov 14, 2015 | 11:14 PM
Gibler77's Avatar
Gibler77
Default Battery Quick Connect(s)
Will there be any issues with attaching both a heated gear and trickle charger battery quick connects at the same time? Obviously, I won't ever be using both at the same time, bu will the connectors interfere with one another while either is in use?
Old Nov 15, 2015 | 07:54 AM
SIDECAR BOB's Avatar
SIDECAR BOB
other than sometimes it makes it a bit difficult to keep everything tight it will not cause any problems. I have changed the terminals to fit the battery bolts on some of the harnesses before too.
Old Nov 18, 2015 | 06:02 AM
grbrown's Avatar
grbrown
Just make sure the terminal screws are long enough and that the connectors all lie flat to make good contact with each other, so that the screws can be tightened fully. A lot of power flows through the main cables when starting the bike and it is important that the extra connectors don't interfere. Otherwise you'll be fine. You may be able to wire in your heated gear through the fuse box, which is worth considering, which will reduce the connectors at the battery terminals.
SWThomas
Milwaukee Eight (M8)
21
Jan 17, 2017 06:44 PM
rhuff
2014-2024 Touring Models
Oct 17, 2016 06:27 AM
Tucker99
Nov 12, 2014 10:42 AM
lencap
Oct 18, 2011 11:46 AM
lizdc
Jan 16, 2010 06:18 PM
