Too many things connected to the battery...
Old Nov 11, 2014 | 10:10 AM
Tucker99's Avatar
Tucker99
Default Too many things connected to the battery...
Just hooked up the hot wire for wife's heated vest. The heated gear people recommended against using the battery tender connector so that killed my idea. Now on each terminal I have: Battery charger SAE connector, Equalizer for the LED lights, and now the feed for the heated gear. All that on top of the stock battery cables. Of course all the rings are a different design and they don't mesh well when cranking down on the battery bolts. As I tighten the bolts down, all the circle ring connectors start turning as well making for twisted lines and the rings aren't orientated where I want them. Looked through my JP catalog and didn't see anything. Is there a battery mounted bus bar that might work? What does everyone else do??
Old Nov 11, 2014 | 10:18 AM
dawg's Avatar
dawg
Others have added distribution blocks.
Old Nov 11, 2014 | 10:21 AM
BlackPearl#1's Avatar
BlackPearl#1
I have seen both a small power distribution block used, and another idea that I think works a little better is to use a larger wire gauge ring terminal and crimp more than one wire in it. Hope others chime in with some other ideas for you too. FWIW I think the charger lead is a great idea. That way you don't need to add anything to the post.
Kris
Old Nov 11, 2014 | 10:26 AM
dawg's Avatar
dawg
Old Nov 11, 2014 | 10:56 AM
fabrik8r's Avatar
fabrik8r
or connect your heated gear to the OEM B+ connector
Old Nov 11, 2014 | 11:50 AM
Eunoterpsia's Avatar
Eunoterpsia
Non HD/OEM Equivalent? No side posts?
Attached Thumbnails Too many things connected to the battery...-screenshot-32-.jpg
Old Nov 11, 2014 | 11:53 AM
vickers1's Avatar
vickers1
Why would they recommend against the battery tender connector? It has a positive and negative and so does your heated gear. That's crazy.
Old Nov 11, 2014 | 11:59 AM
Frostbite's Avatar
Frostbite
Smaller wire - no fuse - their lawyer saying 'We'll Get Sued!"
Old Nov 11, 2014 | 12:00 PM
BoonDock_Saint's Avatar
BoonDock_Saint
This should do ya. http://www.wiringproducts.com/batter...-positive.html
Old Nov 11, 2014 | 01:31 PM
Tucker99's Avatar
Tucker99
Ok the Powerlet tip was the ticket. I got the Termin-8, it is exactly what I need. No hard mounting required, $44.95 delivered from Revzilla. Thanks Gents!!
