Too many things connected to the battery...
Old Nov 12, 2014 | 05:55 AM
grbrown's Avatar
grbrown
Thumbs up
Originally Posted by fabrik8r
The chassis ground studs will be in close proximity to the connector. All pre-2015 touring models have the B+ connector(single position grey connector roughly 1/2"X1/2"X 1 1/2",located in the frame cavity forward of the battery compartment). Its a short wire connected direct to the positive post so it is the same as connecting direct to the positive battery post, and the wire is plenty heavy enough to handle the load. The connector typically has the mating half plugged into it, so all you will need is the crimp terminal from the parts counter, probably less than $1.
Indeed, no need for any additional negatives to go direct to the battery! I use a relay, switched from the ignition switch, for my added stuff, although that is pre-canbus.
Old Nov 12, 2014 | 10:42 AM
Mikind7's Avatar
Mikind7
Amazon $41.95 free shipping
Amazon.com: Powerlet PKT-103 'Termin-8' Fuse Block: Automotive Amazon.com: Powerlet PKT-103 'Termin-8' Fuse Block: Automotive
Gibler77
Electrical/Lighting/Alarm
Nov 18, 2015 06:02 AM
lencap
Oct 18, 2011 11:46 AM
al baehr
Sep 29, 2010 11:06 AM
lizdc
Jan 16, 2010 06:18 PM
tr6640
Apr 2, 2008 11:23 AM
