Horn, turn signals, brake lights not working
Old Feb 23, 2016 | 06:00 PM
michaelapokorny@gmail.com's Avatar
Stage III
Default Horn, turn signals, brake lights not working
My bike is a 2007 Street glide. The Horn, Brake light, and turn signals quit all at the same time. I check the wiring in the bars and all is good. I noticed the turn signals, horn and brake switch is wired together. I check the buld for the brake light and the fuse, all is good, Also checked for the turn signal and all is good,. I know the bulbs work because they still flash with the alarm. Is there a graound or something that I can check that is beyond the wiring in the bars and before the lights, That is all I can think it would be.
Thanks for any ideas
Old Feb 23, 2016 | 06:47 PM
madsonp's Avatar
madsonp
Check your e-mail, I sent you something that might help. I'm kinda thinking it's a ground issue.
Old Feb 24, 2016 | 07:01 AM
Vernal's Avatar
Vernal
Welcome to the Forum!
Check your accessory fuse it provides the power to everything you mentioned.
Good luck
Bill
Old Feb 24, 2016 | 04:05 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Is it a secret?
Old Feb 24, 2016 | 04:20 PM
madsonp's Avatar
madsonp
Is it a secret?
No, I sent him the wiring diagrams for his bike.
Old May 7, 2016 | 11:24 PM
digger58's Avatar
digger58
Had the same issue last night, turned out to be a wire from the horn that touched the cylinder head and melted, instant short.
New fuse, wire repair and good to go.
Hope yours is that easy
Old Jul 10, 2018 | 11:33 AM
Mat0722's Avatar
Mat0722
Stage IV
Default Help
I am having the same problems on my 09 FLHTP. I recently installed LEDs all the way around and a Cust Dynamics Load Equalizer. Went for a ride last week and had no turns brake or radio. I've replaced the fuses and checked the relays. everything appears to be good. only other thought might be TSM???
Old Mar 28, 2022 | 02:56 AM
Nocahones's Avatar
Nocahones
Stage I
Good luck
Bill
Bill, Thanks for the tip. Not only were you right but it saved me a bunch of time looking at wiring. I checked the obvious fuses and relays but didn't expect the Accessory fuse to run those things. Thanks again
Old Mar 28, 2022 | 03:50 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Be sure to jump over to the New Member Area and do your first new post.
Welcome from North Beach, FL., USA!
Just in case you have not done this.
Add a Signature Line in your USER set up for your bike year, model, and all the letters that Harley recognizes it with so others see at the bottom of all your post. This enables others to know your exact model if you ever ask a question.
And a Avatar of your favorite shot in the USER set up for the small picture others will see in the top left corner of your post.
​​Your all set.... Enjoy the ride! ______________
Old Mar 28, 2022 | 04:02 AM
Andy from Sandy's Avatar
Andy from Sandy
Power through the accessory fuse allows you to have the hazards running with the bike's main power switched off.
