Blowing ecm fuse!
Old Mar 20, 2016 | 02:31 PM
  #31
TimmyG's Avatar
TimmyG
Ok after looking i can see the fuse panel labeled. I skiped tested the rely, i swaped in another one, step 2 3d to ground i do have voltage. Skip to step 3. Not sure how to find 85b terminal a
Old Mar 20, 2016 | 02:34 PM
  #32
TimmyG's Avatar
TimmyG
Ok ill look at the yellow green wire.
There is no reason to be checking for power, you know that the ECM fuse is blowing, and since it only blows when the ignition kill switch is on, we know that the short is somewhere after the system relay (Yellow/Green wire).
Follow that Yellow/Green wire and look for any chafing on the insulation or sheathing. If nothing obvious, unplug all the connectors for the circuit, and check for continuity to ground with a multi meter. Move the wires around while checking with the meter and look for a change.
Old Mar 20, 2016 | 02:45 PM
  #33
TimmyG's Avatar
TimmyG
Ok that wasnt so hard, i found my o2 plug wires pinched under the transmission cover. Hopefully that solves this
Old Mar 20, 2016 | 02:58 PM
  #34
TimmyG's Avatar
TimmyG
Now to see if i should replace it or fix it
Old Mar 21, 2016 | 04:37 PM
  #35
TimmyG's Avatar
TimmyG
I want to thank both of you guys for your help!
clap
Apr 5, 2017 08:07 PM
FATKEVIN
Oct 25, 2014 08:33 AM
Nielsds
Feb 11, 2014 10:59 AM
bigbobby
Feb 6, 2010 08:28 AM
drogers
Jun 1, 2008 06:26 AM
