Enne guard light wiring
Old Apr 19, 2016 | 05:37 PM
55ironhorse's Avatar
55ironhorse
Default Enne guard light wiring
After removing the existing factory spot lamps from the front fairing area, I am in the process of installing a set of Harley engine guard lights (68913-98C) on my 2008 Street Glide. Not using the supplied wiring loom from the engine guard lights, I took a short cut on wiring the lamps to the existing power supply from the previous spot lamps. This allows me to use the existing power switch on the ignition panel, which is connected to the head light, which uses a 15 amp fuse. Question is ....will this application cause any electrical issues or battery drain? Thanks for any input..........
justgeorge
2014-2024 Touring Models
Aug 18, 2020 07:32 PM
wam6187
Electrical/Lighting/Alarm
Mar 31, 2015 09:13 AM
UltraNutZ
Touring Parts
Nov 11, 2013 06:16 PM
UltraNutZ
Nov 11, 2013 10:31 AM
HDChloe
Feb 23, 2008 02:54 PM
