What's This Code Mean?
Old May 24, 2016 | 02:28 PM
hd4evr2008's Avatar
hd4evr2008
Default What's This Code Mean?
Went to start my bike after riding about 1/2 hour, and I get NOTHING from the starter button. Like I don't even have the key on. Bike was running fine, then this. I have lights and battery cables are nice and tight. I'm getting fault code B2121. What does this mean? Solution? Thanks!
Old May 24, 2016 | 03:38 PM
qtrracer's Avatar
qtrracer
Starter Output Open
Old May 25, 2016 | 02:14 PM
Vernal's Avatar
Vernal
From 2015 EDM:
Pull the solenoid wire and hook a volt meter between it and ground. Turn bike on and hit the start switch 12V means you have a bad solenoid.
If no voltage go to the BCM and check the red/black wire L2 starter solenoid power to ground. If no power there the BCM is bad. If you have power there you have a open wire yo the solenoid.
Did you try unplugging the solenoid and using a jumper from the starter battery connection to see if it will crank?
Good Luck
Bill
Old May 25, 2016 | 03:23 PM
hd4evr2008's Avatar
hd4evr2008
Bike is still under warranty so it's at the dealership now.
Old May 25, 2016 | 04:04 PM
Vernal's Avatar
Vernal
Let us know what they find
Old May 25, 2016 | 04:10 PM
hd4evr2008's Avatar
hd4evr2008
I will. He just called and said it's scheduled to be looked at tomorrow, and he'd call me when they find out something.
phantom33
Dec 19, 2016 02:55 PM
cunfuzed
Jul 3, 2014 04:33 PM
Rocker_C
Aug 8, 2012 12:32 AM
busterman2
EVO
14
Jun 20, 2012 06:18 AM
saweet96
Jul 15, 2006 03:20 PM
