Tach Compatibility
Old May 31, 2016 | 06:26 PM
CarlosGGodfrog's Avatar
CarlosGGodfrog
Default Tach Compatibility
I have the chance to get a Harley Davidson 67348-04A Tach. It lists as being from a 04-08 Touring (Ultra and Electra). Is the tach function compatible with a 2000 Heritage. I realize that the cruise and abs lights won't be active, but I need to know if the tach feed will work with a 2000 Heritage Springer. My ignition uses two 12 pin connectors. I will have to fab a handlebar mount. I assume (?) it will have tach, illumination, and ground wires ?
Old Jun 15, 2016 | 12:23 AM
Nadeemw's Avatar
Nadeemw
I had similar questions few months ago but then took my chance and tried. everything worked. my tach was off a 09 RK police and I mounted it on RKC, tach worked fine, illumination, cruise indicator and ABS, since my bike isn't ABS thus ABS light stayed lit in the tach and I could not eliminate it. Only could be done by the dealer to flash it to non ABS bike usage setting. does not bother me though!
In general what you have noted, it will work, just three connectors (+- and data)
Old Apr 18, 2017 | 07:29 AM
58pan's Avatar
58pan
6th Gear
Just did this on my 08 FLHRC. I found disconnecting the O/W (Accessory) wire shut off the ABS light.
Herk1
Jun 10, 2021 11:27 AM
UltraClassicElectraGlide
Apr 27, 2012 05:02 PM
Just Me
Mar 5, 2012 05:45 PM
les63
Jun 23, 2011 12:38 PM
pk
Apr 5, 2008 08:03 AM
