Speedometer Problem
Old Jun 28, 2016 | 05:57 PM
Hodado's Avatar
Hodado
Default Speedometer Problem
My speedometer on my 2002 FLHR has been acting erratically.Bounces from zero to actual speed and then drops down to zero.When I start the bike cold and ride for 15-20 minutes it works fine,then acts up then stops completely.I was told
to remove the speed sensor,clean it off and then re-install.I did that but it didn't change a thing.Is there a way to check to see if the sensor is bad or not?I've noticed that my directionals do not self- cancel anymore.Any direction appreciated!!
Old Jun 28, 2016 | 07:50 PM
14GuineaPig's Avatar
14GuineaPig
Most likely you have to replace the speed sensor. Cleaning it off doesn't always work. As for the turn signals, the TSSM needs info from the speedometer/speed sensor to cancel the turn signals. I assume that your bike is carbed since the fuel injection also gets info from the speed sensor. Also cruise control will not work without speed info.
Old Jun 28, 2016 | 08:39 PM
Crashrdking01's Avatar
Crashrdking01
Default Thx
i am having the same issues with my 01 FLHRC
daGreek55
May 30, 2018 09:51 PM
tallrider13
Apr 5, 2017 02:05 PM
olelucky
Jan 1, 2015 03:47 PM
pmcburne
Jul 3, 2013 07:03 PM
jasle
Electrical/Lighting/Alarm
Jul 19, 2009 07:24 PM
