Speed Sensor
Old Dec 30, 2014 | 05:11 PM
olelucky's Avatar
olelucky
Default Speed Sensor
i recently bought a 1200c for my girlfriend to learn to ride. everything worked and was fine except it shifted odd. i remove the transmission and found a burr on a shifting fork. that fixed that. but now the speedo doesnt work. it lights up, shows milage and tripometer, but doesnt register speed. which sounds like a speed sensor. all code show clr. my question, is there something else to check? why would a speed sensor go out just removing tranmission? thanks
Old Dec 30, 2014 | 07:56 PM
Scuba10jdl's Avatar
Scuba10jdl
The speed sensor reads off of the 5th gear. You didn't bungle it up or bash it while working on the tranny?
Also, it's probably just the speedo connector. Under the bike. Mine has gone wonky a few times for no reason at all.
Old Dec 31, 2014 | 10:26 AM
Roster's Avatar
Roster
If your turn signals cancel like they should then it s not the speed sensor..if they don't cancel I would suspect you have some crap stuck to the sensor, pull it out and clean it off.
Old Jan 1, 2015 | 03:47 PM
olelucky's Avatar
olelucky
i did have a jack under it to rotate the tire while on the lift. so ill check the connector under there. also i didnt know about the blinkers not canceling. i'll check that also, thanks
pmcburne
Jul 3, 2013 07:03 PM
shakrr
Mar 31, 2013 07:22 PM
bbxbest
May 11, 2010 12:41 PM
jasle
Electrical/Lighting/Alarm
Jul 19, 2009 07:24 PM
Jkid
May 3, 2007 05:02 PM
