speed sensor bad?
Old Feb 17, 2013 | 06:40 PM
shakrr's Avatar
shakrr
Default speed sensor bad?
My turn signals wont cancel I cleaned my sensor and they still wont cancel but the speedo works fine is my sensor bad?
Old Feb 17, 2013 | 08:29 PM
dawg's Avatar
dawg
Well it could be the sensor is bad or it could be the TSSM. Replace the sensor with a known good one and see.
Old Feb 17, 2013 | 09:21 PM
Hotrodz_n_Harleyz's Avatar
Hotrodz_n_Harleyz
I suppose anything's possible, but really, if the speedo is working and not jumping around and doin weird stuff, then it's working. I would be pretty surprised if just the auto cancel quits and it's the sensor. there aren't any separate parts or anything, it's just one little round piece that sticks in there.
Old Feb 17, 2013 | 09:30 PM
soft 02's Avatar
soft 02
Mine did that and it was the speed sensor. Dam gear hit the sensor and messed it up.
Old Feb 17, 2013 | 09:49 PM
Harleypingman's Avatar
Harleypingman
Anyone checked the wiring diagrams in th service manual?
Old Feb 18, 2013 | 06:08 AM
shakrr's Avatar
shakrr
I also changed the TSSM which was a expensive no cure
Old Feb 19, 2013 | 12:02 AM
Fishrrman's Avatar
Fishrrman
If your speedometer still works as it should, it might not be the speed sensor itself, but the connections between the sensor and the turn signal module.
(Could there be a connection between the _speedometer_ itself and the turn signal module that is bad?)
Old Feb 19, 2013 | 12:05 AM
marknett's Avatar
marknett
Just changed one on my 96 sporty . signals would not cancel but the speedo wasn't working either. sensor fixed both
Old Mar 31, 2013 | 06:44 PM
shakrr's Avatar
shakrr
Well I finally got to ride yesterday I replaced the speed sensor and they still wont cancel WTF! this started after my motor rebuild anything else simple I should look for or I need to get used to turning them off
Old Mar 31, 2013 | 07:22 PM
btsom's Avatar
btsom
Any codes stored?
cc_Penguin
Jun 11, 2021 01:10 PM
dennisj1988
Jul 27, 2018 01:50 PM
lip
Feb 5, 2013 04:07 PM
Twilly
Aug 23, 2012 10:08 AM
FreddyP
Jul 7, 2006 11:42 AM
