I have a 2005 Dyna Low rider FXDLI that I purchased used 4 years ago. About 1-2 times a year it would shut down electrically while riding. Coast to side of road, cycle the ignition key and it would start again. A few week ago I stopped to fuel it and it would not start. After disconnecting/reconnecting the battery it started right up. Several days later it just won't start. I have power in "ACC"
mode but when I move key to "Run" there is no power. I have a new battery and have had it tested (it is fine) I have replaced the ignition and no change. I replaced the starter relay and no change. I have checked fuses and regreased them. I have traced down wires and found nothing loose. Does anyone have any ideas for me? Thanks!
Ok, I figured out how to access the codes...holding the odometer button in while turning ignition key. Again I have power during the "ACC" mode but nothing during "Run". No codes come up. Could this be the computer module/ECM?
I recommend you get yourself a factory service manual for your bike, if you don't have one. There are diagnostic tests for electrical problems, which may help you solve the problem.
