Accessory question???
Old Sep 15, 2016 | 07:37 AM
fatboy1729's Avatar
fatboy1729
Default Accessory question???
Hello forum, have an 06 FatBoy that the battery compartment is a cluster of numerous wiring going to battery terminals and grounds due to aftermarket accessories... want to make it look neat but what to do to do this??? Any help is appreciated... Thanks in advance for replies...
Old Sep 16, 2016 | 06:25 AM
grbrown's Avatar
grbrown
Depends what the accessories are, but a simple thing to do is create a parallel circuit, feeding the extras. Use a relay on a fused circuit, available from any auto parts store. That will require only one ground and one power wire and you can switch it on from your ignition switch. If the accessories are all at the front of the bike, you can use a single power cable from the relay to a local distribution board - or similar.
Old Sep 16, 2016 | 06:49 PM
fatboy1729's Avatar
fatboy1729
Thank You for the advice!!!
cmc seabee
Aug 11, 2015 11:56 PM
OriginOfEvil
May 14, 2013 11:03 AM
mjackson61
Jul 10, 2011 10:07 PM
81fxb
Aug 6, 2008 05:16 PM
RonH
Jan 21, 2008 04:32 PM
