No Power at Ignition Switch?
Old Jul 9, 2011 | 11:39 PM
mjackson61's Avatar
mjackson61
Stage II
Default No Power at Ignition Switch?
I turn on switch and nothing comes on. I can try later and it does. When I try to start engine it bumps the stater and I lose all power again. Any suggestions? 2006 Super Glide Custom.
Old Jul 9, 2011 | 11:47 PM
Sgt. Fury's Avatar
Sgt. Fury
How old is the battery? Are the cables tight, and is the connection clean? Could be a bad circuit breaker, broken down cable, battery, switch, or a bad connection somewhere in the wire bundle.
Old Jul 9, 2011 | 11:57 PM
Little Mike's Avatar
Little Mike
Sounds like a loose ground cable, had that problem fairly often on my Heritage.
Old Jul 10, 2011 | 01:22 AM
MidnitEvil's Avatar
MidnitEvil
Loose battery connection. I had the exact same thing a few weeks back.
Old Jul 10, 2011 | 06:40 AM
oldairboater's Avatar
oldairboater
Battery good? Cables clean and tight? HD's need to be right when it comes to engaging the starter. Too many people neglect thier batteries and their terminals.
Old Jul 10, 2011 | 11:27 AM
rhlhamlet's Avatar
rhlhamlet
Originally Posted by oldairboater
Battery good? Cables clean and tight? HD's need to be right when it comes to engaging the starter. Too many people neglect thier batteries and their treminals.
I ignored my "treminal" just the other day......
Old Jul 10, 2011 | 06:40 PM
ElectraDave's Avatar
ElectraDave
I'm still ignoring my "treminals".
Old Jul 10, 2011 | 07:03 PM
Sgt. Fury's Avatar
Sgt. Fury
I ignored a treminal once. It got ugly.
Old Jul 10, 2011 | 08:47 PM
oldairboater
Okay, I missed spell check. lol
Old Jul 10, 2011 | 10:07 PM
ROMPUS's Avatar
ROMPUS
had about the same thing happen and took off battery cables and sanded the ends of them even tho they looked ok.took the ignition switch apart and shined up the contacts in it with 000 steel wool replaced the circuit breaker with 40 amp fuse link.all of that solved my problem.good luck!!
T-rat
Sep 14, 2014 07:47 AM
see22ds
Electrical/Lighting/Alarm
May 22, 2014 04:43 PM
TUCCI
Jan 8, 2012 07:56 PM
kaathrin
Jun 13, 2009 02:47 AM
calebv
Dec 5, 2008 10:42 PM
