Battery Charging Question
Old Mar 25, 2017 | 02:44 PM
jamala00's Avatar
jamala00
Default Battery Charging Question
I have an '09 Ultra with a 3 year old HD battery. I keep a charger/maintainer on it every winter. (Which I did this winter) However I noticed that the maintainer charged LED was not lit rather the charging one was. Normally in the spring the charged LED is lit. I checked the voltage of the maintainer along with the current output. Both seem very normal. Took the battery out of the bike and hooked up the charger/maintainer. After a couple days, still wouldn't indicate charged. Took the battery into the HD shop to have it load tested, they said it's good.. Output was charge time 5 minutes.... 373 CCA, 12.51 volts. So I thought OK, something is wrong with my charger/maintainer... Picked up a new one, hooked it up and still the new one will not indicate it's charged. The new one has a readout for percent charged and it stays at 73%
Can there be something up with the battery even though the HD shop load test came back and said that battery was just fine?
Old Mar 26, 2017 | 01:24 PM
jamala00's Avatar
jamala00
Solved my own issue.
Old Mar 28, 2017 | 08:25 PM
FLRoadKing's Avatar
FLRoadKing
Glad to hear your fixed up. What was the problem?
I keep battery tender on mine all the time, everyday and or night unless in not home.
fRESH88
Oct 23, 2019 03:51 PM
sabunimwil@gmail.com
Apr 10, 2017 10:01 AM
My2Harleys
Electrical/Lighting/Alarm
Jul 22, 2014 06:52 AM
Bigger Hammer
Jun 16, 2010 11:39 AM
84sugar
Sep 10, 2009 05:54 PM
