Starter issues
Old Apr 15, 2017 | 10:39 PM
97Heritagerider's Avatar
97Heritagerider
Default Starter issues
I have 97 Heritage with a Total Performance 121" motor in it.
Everything was fine, then I went to start er and click click wtf
I replaced the battery to troubleshoot because it was in there since 2015.
Tried to start it and click click (from starter)
I tried to rock her in gear and still nothing.
Ran beautiful and now I don't know a good wrench in West Palm
Old Apr 16, 2017 | 07:08 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Put your hand on the starter and press the start button, can you feel the solenoid moving in the starter?
If so, it most likely means the electrical contacts in the solenoid need to be replaced.
You can get a solenoid rebuild kit from any starter repair shop (these are very common automotive starters), or you can get a more expensive (not better) kit from the dealer.
If the solenoid does not move when the start button is pressed, it is probably a bad starter relay, they are cheap, even from the dealer.
Old Apr 16, 2017 | 11:53 AM
97Heritagerider
I just checked and there is movement when I hit the starter button. Does the starter need to come out to replace those items?
Old Apr 16, 2017 | 08:12 PM
Dan89FLSTC's Avatar
Dan89FLSTC
No, disconnect the battery and remove the end cover from the solenoid (not the starter motor).
You should be working with a factory service manual...
Old Apr 16, 2017 | 08:25 PM
97Heritagerider
I'm no mechanic b
There wasn't a big hint of trouble either
Old Apr 16, 2017 | 08:26 PM
97Heritagerider
Solenoid is the smaller unit?
garystaven88
Electrical/Lighting/Alarm
Oct 25, 2015 11:39 AM
Bill Barham
Engine Mechanical Topics
Oct 8, 2013 08:57 AM
hardheaded
Shovelhead
Jul 1, 2013 12:11 AM
pd76
EVO
May 7, 2012 07:22 PM
pedulla242
Mar 2, 2011 11:12 PM
