97 EVO will not start
Old Oct 7, 2013 | 11:06 AM
Bill Barham's Avatar
Bill Barham
2nd Gear
Default 97 EVO will not start
'97 EVO EFI w/130,000 miles......engine fails to start....click when depressing START button.
I've been able to rock bike in gear in the past and engine will start. Someone suggest a binding jack shaft may be the culprit. Very random problem but now no success.
Thanks for any ideas.......Greasy
Old Oct 7, 2013 | 04:14 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
How loud is the click, faint or loud? Put your hand on the starter and push the start button, do you feel the solenoid move?
A nice healthy clack from the starter means the solenoid is operating, but the electrical contacts in the solenoid are not making contact to send juice to the starter motor.
You can buy a solenoid rebuild kit from the dealer, (at HD inspired prices), or you can go to a starter shop and get the same exact parts for small change.
If you hear a very faint click, and can feel nothing when your hand is on the starter, it is probably a bad starter relay.
Starter relays are cheap, even from the dealer.
Old Oct 7, 2013 | 09:37 PM
GraemeR's Avatar
GraemeR
connect another battery via jumber leads so that you rule out a dead battery. otherwise its the relay, solinoid or copper contact ring ring in the solinoid.
Old Oct 8, 2013 | 08:54 AM
Bill Barham
2nd Gear
[QUOTE=Dan89FLSTC;11848617]How loud is the click, faint or loud? Put your hand on the starter and push the start button, do you feel the solenoid move?
I pushed the START button with my hand on the starter.....nice thunk was felt.
Thanks for your help.
Old Oct 8, 2013 | 08:57 AM
Bill Barham
2nd Gear
New battery and on battery tender....
Thanks for your input/
mbierbac
May 19, 2024 09:15 PM
97Heritagerider
Electrical/Lighting/Alarm
Apr 16, 2017 08:26 PM
garystaven88
Oct 25, 2015 11:39 AM
hardheaded
Shovelhead
Jul 1, 2013 12:11 AM
pedulla242
Mar 2, 2011 11:12 PM
