thru batteries again
Everything electrically is new and includes wiring regulator stator starter ign battery earth straps all of which run through a motogadget m unit v2 box bike sta rats first push and runs great only problem is that I am now on my 5th battery as they go flat and won't recharge or melt terminals all run on optimate or oxford 900 tender charger ??
I cannot find the culprit or reason it does this but bike is 89 evo everything has been checked over and over .
Does anybody have any help to solve please.
Start with a good charging system test:
https://www.hdforums.com/forum/evo-c...ng-system.html
Then search for the circuit causing the drain:
There is also an Evo sub forum here with a lot of knowledgeable people:
https://www.hdforums.com/forum/evo-classic-models-84/
Also, even a little corrosion can cause weird and elusive problems like this. Sometimes you just have to start pulling things apart and looking for something not right, and sometimes you cannot find anything wrong and it all works great when you get it back together. When that happens, you are in for a world of problems.
Good luck!
Melting terminals is a symptom of a bad connection.
Perform a parasitic draw test.
