Turn Signal Help
Old Jun 6, 2017 | 06:36 PM
twoskies's Avatar
twoskies
Default Turn Signal Help
Hi All
got a 1996 FLSTN heritage softail, hd dyna turn signals,everything worked until recently, no leds, regular bulbs
turn signals work when bike is not running, work sporadically when running, 4 way flashers always work,
tried the manual, ive got good ground on pin1, battery voltage (12 volts ) on pin 2,
i can jumper from 2 to 3, or 2 to 4 and lights light up front and back,
when trying turn signal with bike running the turn signals light but wont flash or only flash 3 or 4 times then stop,
daughters sportster had the same turn signal module(works on her bike)wont even flash not running on mine
any help appreciated
ill check the forum every couple days
Thanks
Old Jun 6, 2017 | 06:40 PM
twoskies's Avatar
twoskies
HI All
just a quick add to this thread
my speedometer works fine, was told the cancelling system was tied into turn signals and if it was not working, might be the issue
tHANKS
Old Jun 6, 2017 | 06:46 PM
RANGER73's Avatar
RANGER73
You swapped module with the sportster and your module worked in the sportster?
Did the sportster module work in your bike?
Old Jun 6, 2017 | 08:01 PM
twoskies's Avatar
twoskies
lol, i swapped the sportster module to my heritage and would not work, i have not tried to put the heritage module in daughters sportster, same exact part number
that would eliminate the module
Thanks
Old Jun 6, 2017 | 08:47 PM
twoskies's Avatar
twoskies
update
i swapped the heritage module to my duaghters sportster and it worked fine, so either 1 of the 2 modules work on the sportster but not on my heritage
side note, heritage runs fine except turn signals not working, only issue
Thank You for any and all help
Old Jun 8, 2017 | 06:18 AM
twoskies's Avatar
twoskies
got it, bad connection on rear turn signals under rear fender, recut and soldered and booted, works like it should now
Thanks
Old Jun 12, 2017 | 06:25 AM
RANGER73's Avatar
RANGER73
Lost track of this thread
Ya, the TSM needs to see the load from both bulbs to work. That's how it tells you you have a bulb out or like in your case a broken wire.
Old Jul 3, 2017 | 02:43 PM
mike4045's Avatar
mike4045
4th Gear
Any leads on finding a replacement turn signal relay? I have same issue on my 03 sportster. Do they have to be purchased thru Harley dealer?
Mike
SarahHenry1124
Apr 6, 2015 02:34 PM
divco13
Jan 7, 2014 11:38 PM
tomnick
Apr 8, 2012 02:12 AM
Boxman420
Nov 23, 2011 11:55 PM
frankjc
Aug 4, 2010 01:48 PM
