Turn signals right side not working, only riding light is on
Old Jul 30, 2017 | 03:34 PM
Skulltail's Avatar
Skulltail
4th Gear
Default Turn signals right side not working, only riding light is on
Turn signals on right not working, front and back only riding light is on , right side. Emergency flashers only left side is flashing. Help ! ! ! Someone please help me. All lights will work, tested front and back, they all light up when I wired them separate, from a hot wire job.To see if bulbs are all good, they all work, no burned out bulbs. Please help me !!!! I did everything in my power to fix the problem.. Could not fix the problem. Thank you,Skulltail
Old Jul 30, 2017 | 03:37 PM
Skulltail's Avatar
Skulltail
4th Gear
What is the web address for online service manual, no luck, Please Help me out ! ! Skulltail
Old Jul 30, 2017 | 08:11 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
First help us...By telling us what you are working on.
The way to get a service manual is simple, put money on the parts counter at the dealership, or buy one online.
Old Aug 1, 2017 | 09:16 PM
Skulltail's Avatar
Skulltail
4th Gear
Default 2004 night train light problem
Hello, look at title for all information, please help. Thank you, skulltail Please help me please, I have a manual now. I can read it and understand it, does not help me locate the problem. Tested right turn signal button switch.. the left had plenty of amps, left side was a lot lower in amps. The right side only one riding light is on, no blinking right side at all, the left side is fine, tested amps of both tun signal button, right side seems low, the left side plenty of amps, arrows console left blinks fine, right side arrow just stays on no blinking. Please Help me out, I am stumped ?. Thank you, Skulltail. New member
Old Aug 1, 2017 | 09:26 PM
Skulltail's Avatar
Skulltail
4th Gear
[QUOTE=Dan89FLSTC;16482725]First help us...By telling us what you are working on, 2004 night train , sorry about what kind of bike I have, very long days for a while, 60 hours a week. Skulltail
Old Aug 2, 2017 | 12:00 PM
Zanthamos's Avatar
Zanthamos
Did you check for shorts to ground, and what about volts? Seems like you may have a short on the right after the switch but before the lights.
Old Aug 6, 2017 | 05:12 PM
DueyD's Avatar
DueyD
Stage IV
I am having an issue similar with my 94 FXST. The left signal works fine but front running light will not light up and my right front light stays on bright and will not blink. Can it be the signal control module?
Old Aug 8, 2017 | 12:04 AM
ER-Thumper's Avatar
ER-Thumper
Having exact same issue on 98 RK, but it's my left turn signal. Running lights are good, but hit blinker & both front & back ambers get a little dim & no flash. Changed rear bulb (had blown element), but made no difference.
Right side works normal, flashers just dim all 4 slightly & no flash.
Old Aug 8, 2017 | 07:41 AM
Zanthamos's Avatar
Zanthamos
Again, I would check for shorts to ground between the bulb to the TSM/TSSM. There should be infinate resistance between the power and ground with the bulbs removed. If you get any continuity, disconnect the TSM/TSSM and check again, still continuity you definately have a short to ground, if no continuity TSM/TSSM may be at fault.
Old Aug 13, 2017 | 11:13 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Your posts are very difficult to follow...
Don`t panic, slow down...
What happens when you press the right turn signal button?
What happens when you press the left turn signal button?
