Wide Glide LED headlignt
Old Jul 31, 2017 | 09:33 AM
Dosahl's Avatar
Dosahl
Stage II
Default Wide Glide LED headlignt
Running a 2012 Wide Glide. Upgraded to an LED headlight replacement. It was not the Harley Daymaker. I went with another highly rated after market unit. Everything fit well and the light looked great - bright and shiny. Problem came after about an hour riding on High Beam. My security light came on (I have no security system) This has always indicated a bulb failure. I continued riding but could not get out of high beam. I rode for a while and then it did go to low but the security indicator stayed lit. I called the headlight company and they had never heard of this. Code check later indicated High beam output open Low Beam output open and High bean output shorted. Headlamp went back to manufacturer. Now I am looking into the Harley Daymaker but 400 is twice the price as my previous model. Just checking has anyone had any code issues with the Daymaker on a Dyna? I do not want to go through the same hassle. My dealer said I would not but you know.......he wants to sell product. I have read of some LOW BEAM issues. I just need some feedback before plopping down 4 big ones.
Thanks
Old Aug 23, 2017 | 09:18 AM
ronp047's Avatar
ronp047
Stage I
Have a 2015 Sportster 883 Superlow. Installed a non Harley brand Daymaker LED headlight replacement. Started riding and after about 15 miles my High Beam indicator light came on followed soon by my security light (nor do I have a security system) and stayed on. After reading your posting I will start my investigation of this problem based on your experience.
Thanks
RonP
Old Sep 21, 2017 | 09:58 AM
Myhog2's Avatar
Myhog2
Stage II
If you have not fixed your problem yet this should do the trick. plug your headlight into it and it into your harness
H4 HB2 9003 Anti Flicker Harness
Amazon Amazon
RiverCityRocker
Aug 13, 2018 01:46 PM
CGLTD
Mar 17, 2018 12:36 PM
CGLTD
Electrical/Lighting/Alarm
Jan 2, 2018 03:53 PM
Lotaluck
Apr 7, 2016 12:42 PM
nchogfan
Dec 4, 2013 05:07 PM
