If you look under your left sidepanel you'll find the fuse box.
This area is known to suffer from corrosion.
Ensure all fuses and the sockets they go into are clean.
More importantly, this is where your starter relay( a small rectangular box) is located. Pull the relay out and again check for corrosion.
As the relay itself is fairly cheap, it might be a good idea to replace it and see if that solves the issue.
