Making proper connection?
Old Sep 25, 2017 | 07:37 PM
jqb12's Avatar
jqb12
Default Making proper connection?
Im waiting for side mount plate bracket and running light to come in to connect to the wires (see pic) that we're in the old tailight assembly. 2012 Dyna Street Bob, CanBus system. My question is this: I'm not opposed to soldering, but I've done this whole rear fender/light thing without having to cut/remove anything so far just in case I ever decide to go back to stock look. I need to tie into just 1 of the wires in this connector with the bolt plate light. How can I do this without simply removing that wire and soldering it to the light?
Old Sep 26, 2017 | 09:11 AM
larsfum's Avatar
larsfum
The best way to do it is to strip back a section of the insulation, then solder in your lead, and shrink wrap. Or you can try positaps
http://www.posi-products.com/posiplug.html
The problem with vampire taps is that they may damage the wire.
Old Sep 26, 2017 | 09:18 AM
jqb12's Avatar
jqb12
I've just learned of posi-taps and connectors. Have you ever used them? If I went that route........would I leave the end of the wire that I'm tapping in to, in the connector, and then tap-in to it a few inches back from where it enters the connector? In other words, I wouldn't have to de-pin the connector at all?
Old Sep 27, 2017 | 10:18 AM
larsfum's Avatar
larsfum
No, you don't have to de-pin the connector. If you google them there are plenty of videos on how to use them.
Old Sep 27, 2017 | 10:59 AM
jqb12's Avatar
jqb12
OK cool. Thanks for the feedback
saz
Nov 3, 2014 08:56 AM
SulphurDave
Oct 14, 2011 07:40 PM
evesweater
Jan 15, 2009 08:27 PM
Screamin00
Feb 23, 2008 03:29 PM
jkenosh
May 24, 2006 05:44 PM
