lighting
Old Oct 19, 2017 | 02:36 AM
Jeffcruz's Avatar
Jeffcruz
5th Gear
Default lighting
hello really need some answers my breakout right front turn signal and running light not working but both rear and front left works fine already change bulbs..
Old Oct 19, 2017 | 04:19 AM
K9F's Avatar
K9F
I am relatively new here myself and am an electrical engineer and was prepared to help. Nevertheless I am also aware of 'Forum Courtesy.'
No introduction, just dive in with questions from the off. One thread not enough for you? The duplicate thread was started yesterday has over 70 views and a couple of suggestions from me. As desperate as you may be for a resolution you too need to provide feedback on the original thread not just simply raise another almost identical thread the next day!
https://www.hdforums.com/forum/gener...-lighting.html
Old Oct 19, 2017 | 05:15 AM
Iceman24's Avatar
Iceman24
Throw us a bone here...any recent upgrades (bars, lights, electrical)? Turn signal relocation kit? Just stopped working, huh, did you meter the wires to see if there's a break/short somewhere?
Old Oct 19, 2017 | 05:54 AM
K9F's Avatar
K9F
He used a 'light tester' of some descript on the other thread together with a suggestion from myself to which there has been no retort? Duff bulbs, high resistance or bad earth/ground from the holder would be my first port of calls to investigate together with a multimeter.
Old Oct 19, 2017 | 06:45 AM
RANGER73's Avatar
RANGER73
K9F,
FYI, its a battery, there’s no earth ground
Old Oct 19, 2017 | 07:25 AM
larsfum's Avatar
larsfum
Originally Posted by RANGER73
K9F,
It is a ground in the US. It is earth in the UK. That's why he had a slash in between the two that got lost in your quote.
Old Oct 19, 2017 | 07:38 AM
RANGER73's Avatar
RANGER73
OK, if that's true. HOw does earth play a role in a battery's power distribution?
This is a very misleading terminology. Only in the UK would a battery NEG be referred to as earth.
Old Oct 19, 2017 | 08:35 AM
K9F's Avatar
K9F
..... Only in the UK would a battery NEG be referred to as earth.
It is not the battery negative terminal itself that is classed or labelled as earth return but the path the negative takes through the frame.
I'll not split hairs here and please accept my apologies for any misunderstanding. 'Larsfum' is correct we very rarely if ever use the term 'ground' hence the slash was indeed inserted to prevent any ambiguity.
Where the battery is strapped/tied/linked/connected to the frame this in the UK is regarded as the 'earth return.' At almost any point on the bare metal frame this will provide you with the earth/ground/negative return (or whatever terminology suits) naturally required to make any circuit function. The positive aspect hopefully needs no explanation but is as important as the negative/earth/ground return. It is the positive that is red in colour not the earth as implied in your quote, but I may have misinterpreted your post as you did mine?
I also have an inherent disdain about white wall tyres. Sorry 'tires.' Only having been an electrical engineer for 40 years, 32 of that in the Military I obviously didn't try hard enough, next time I will try to do better. Sorry.
Old Oct 19, 2017 | 04:10 PM
Jeffcruz's Avatar
Jeffcruz
5th Gear
good morning peep. my bad for posting a second post . how ever yes I was using LED. when the front right running/signal light went out .so I had replace it with all new regular bulbs. still not working . thanks for the feed back but will have Harley shop take a peek at it hoping it won't be a big problem.
Old Oct 19, 2017 | 05:35 PM
RANGER73's Avatar
RANGER73
If the bike is newer than 98 it uses a wired ground. If both lights are not working then I say it’s the ground. Follow it back to the connection under the seat.
txphatboy
Electrical/Lighting/Alarm
Dec 29, 2016 01:51 AM
billybobnpeggy
Jul 13, 2011 06:50 PM
stev0n
Feb 19, 2011 09:01 AM
aintgutno
Jun 25, 2007 11:03 AM
gvb
Apr 7, 2005 08:30 AM
