Another Custom dynamics led problem... HELP!!!!
Old Feb 3, 2018 | 01:22 PM
Chesapeakebayll@gmail.com's Avatar
6th Gear
Default Another Custom dynamics led problem... HELP!!!!
I cant find any threads for the problem im having. I have a 2012 iron. I installed all around custom dynamics led's turn signals and brake lights. Everything works fine until I turn on my signals. The signals will go back off but the signal indicator on my cluster remains on. And once that happens I lose my brake lights I still have running lights but when i apply the brake, the lights do not get brighter. I currently do not have a load equalizer installed but I was under the assumption that the load equalizer only fixes the hyper flash. Had anybody else had this problem or point me in the right direction.
Old Feb 3, 2018 | 02:55 PM
Front Sight's Avatar
Front Sight
Can’t help with your problem and I know it’s Saturday but if you call them first thing Monday morning they will get you right. Their customer service is second to none. I found it out first hand when I had issues on my scoot. Good luck!
Old Feb 3, 2018 | 08:20 PM
6th Gear
Yeah i figuried id try that as my next step. Just wanted to see if anybody else has had this problem. Thanks for the advice though.
Old Feb 3, 2018 | 08:51 PM
RANGER73's Avatar
RANGER73
Put the stock bulbs back in (1 at a time) to see if the problem goes away.
Apr 29, 2024 03:40 PM
danmo
Jun 19, 2015 09:09 AM
fatboy1729
Jun 12, 2013 11:32 AM
mtnroadking
Mar 17, 2013 03:19 PM
totprod
Jun 16, 2010 03:58 PM
