Hi friends, I have been browsing the forum but couldn't found something similar, I have checked lines, sensor, fuses and other wiring related problems. The problem is that the speedometer of my 1995 Sportster 1200 gets stuck on 90 miles when energized and shows an 0Pr092.1 message but cant find if its a code or what, will appreciate your comments.
[QUOTE=Cokaroshi;17377573]Hi friends, I have been browsing the forum but couldn't found something similar, I have checked lines, sensor, fuses and other wiring related problems. The problem is that the speedometer of my 1995 Sportster 1200 gets stuck on 90 miles when energized and shows an 0Pr092.1 message but cant find if its a code or what, will appreciate your comments.
thanks
Hi, not sure if this helps, but my speedo did similar, no speed/no odometer, I changer out my vss.. Vehicle speed sensor, but that was not issue.. Then I changed out speedometer, bam.. That was it. Speedo OK odometer.. Ok and self cancel turns OK..
