brake lights
Old May 22, 2018 | 01:00 PM
crowbar7817's Avatar
crowbar7817
Stage II
Default brake lights
just changed out my rear brake arm on my 2016 Street Glide Special.
now the brake lights are stuck on.....they said be careful moving master cylinder or damage
anyone know what the damage could be....sending unit?
Old May 23, 2018 | 06:45 AM
enodrano's Avatar
enodrano
The Master Cylinder has a piston that is held out by a spring. When you apply the brake, the lever it pushes in the piston, activating the Brake Light Switch. When you release the Brake Lever the piston gets pushed back out by the spring deactivating the Brake Light Switch.
There could be several issues:
  1. The new lever is heavier than the old one, not meant for your bike, or improperly installed.
  2. The Piston/Sleeve is dried out (Lubricate with Brake Fluid).
  3. The Spring is worn or damaged. (Buy a rebuild kit)
  4. The Brake Light Switch is damaged or the wires are disconnected or damaged. (
Also, verify your Front Brake is operating correctly to rule that out
Good Luck!.
Marks57
Electrical/Lighting/Alarm
Mar 27, 2017 10:22 PM
jthunder
Apr 5, 2014 05:47 PM
Joboo1966
Aug 28, 2010 11:24 PM
FireRyder09
Jan 18, 2010 12:44 PM
JoeGrapes
Aug 5, 2009 07:23 PM
