Need help please!
Old Jun 12, 2018 | 02:20 PM
Adam Stallings's Avatar
Adam Stallings
Stage II
Default Need help please!
I just changed my rear fender and attempted to Change grips but thanks to eBay they were wrong .
Any I bought an after market cvo fender and harness. Ever since I put it back together my accessories won’t turn off with the ignition switch ( radio, dash lights, parking lights all staying on. If I turn the power but off on the radio it’s self it will all go off. Oh it is an aftermarket radio also. I have installed voltage equalizer for taillights also. Any help would be appreciated. 2008 street glide
Old Jun 12, 2018 | 02:37 PM
Zanthamos's Avatar
Zanthamos
Have you tried to isolate out the harness that was installed? That is where I would start, the only wires that should be always hot are RED not RED and any other color so I would look for anything funny like that. Maybe the O/W wire got swapped with a R wire in one of the connectors causing the O/W wire to always be hot.
Old Jun 13, 2018 | 07:53 PM
Adam Stallings
Stage II
Yes I’ve done just about everything narrowed it down to must be a short somewhere on the radio memory circuit. I have even installed the parts o took off to make sure the new ones were not the problem. Does any one have wiring diagrams for the radio memory circuit ?
Old Jun 14, 2018 | 08:19 AM
Zanthamos's Avatar
Zanthamos
Check handlebar switch harnesses for a possible pinched wire.
CVO-RK
Audio Systems
11
Apr 22, 2013 09:26 AM
traxster
EVO
May 25, 2012 10:12 PM
Trippie
Nov 12, 2009 09:27 PM
motor unit 1
Apr 4, 2008 09:14 PM
DK
Feb 20, 2006 08:04 PM
