VOES elimation possible?
Old Jun 15, 2018 | 06:34 PM
BiggCliff412's Avatar
BiggCliff412
Default VOES elimation possible?
I have a 97 wide glide 80" 32k miles. Not getting a good strong vacuum on my carb slide so I am thinking the VOES may be the issue since I already rebuilt carb. I do have a bad voltage regulator confirmed by multimeter tests.
Would the voltage regulator being bad have any effect on lift of vacuum piston in the carb?
Anyway to eliminate the Voes by some aftermarket parts/mods?
Old Jun 16, 2018 | 08:42 AM
Ed Ramberger's Avatar
Ed Ramberger
You should check the slide diaphragm for a pinhole, tear or bloating.
If you have installed the needle jet upside down (curved side faces up) it will barely get out of it's way then kind of turn on. This is the silver tube with the collar on it that the slide needle passes through. Again - curved side faces up.
The Voes simply receives intake manifold vacuum and is either on or off - it's a vacuum operated switch. This should not affect your carb slide.
The voltage regulator will not affect intake vacuum.
If I remember correctly you've had a few threads on charging and carbs. If you've done anything pertinent, it would be good to share it here so we can help as accurately as possible!
Old Jun 17, 2018 | 09:50 AM
BiggCliff412
Yes. Have been fighting the carb and Ive been over it so thoroughly Im 1000% certain its not the carb at all.
I charged the battery and the voltage dropped to under 11.5V after sitting and not being even started in 2 days. I recharge battery and this time and unplug regulator and battery stayed charged fully.
I checked the stator and VR according to the testing pinned here. Only issue I had was a tiny blip on the volts on the meter when checking VR with black lead to ground. Every other test passed.
I only thought the VOES switch was an issue because putting compressed air thru the carb with it off the bike opens and closes normally. Installed seems to have some hesiststion.
Old Jun 17, 2018 | 10:21 AM
Ed Ramberger
you cannot put high pressure air to the carb diaphragm. It can damage it and the volume will overcome any tiny hole.
you can use a straw to blow in the port or like this guy with very very low pressure.
Old Jun 17, 2018 | 11:02 AM
BiggCliff412
Shane Conley videos are my single most used resource after the service manual. I did this procedure exactly. Even after testing it, I still replaced it and got the same speed of operation.
I am admittedly replace happy on this bike. The dealership had no info on its history except for the oil change, front brake and tire they did to make it pass PA inspection.
32k miles, I figure stuff will go bad eventually so just start replacing anything thats not in tip top shape
Old Jun 17, 2018 | 11:31 PM
Zanthamos's Avatar
Zanthamos
If the slide operation is not smooth with vacuum pressure try a manual manipulation of the slide see if you need to do a polish on the slide and the carb side, you may be getting some binding there, another source is the needle itself, have you verified that the needle jet is installed correctly as pictured in the previous post? Check the diaphragm as was previously mentioned as well if you didn't have the binding with manual manipulation. Is the hole blocked in the slide? Has someone enlarged the hole too much? I have had very good luck with CVP parts, I really like the performance of their needle.As far as charging issues go looks like you may be having a paracitic drain with that VR if yuy are getting any continuity to ground, so Chang it out.
BiggCliff412
Carburetor Related
27
Aug 10, 2018 11:54 AM
Wideripper
Aug 13, 2017 07:50 PM
Wideripper
Carburetor Related
Aug 10, 2017 04:50 PM
Wideripper
General Topics/Tech Tips
Aug 9, 2017 08:51 PM
Jay09Cee
Shovelhead
Apr 30, 2014 07:49 PM
