Speedometer Gone Crazy 2013 Roadking
Old Jul 21, 2018 | 03:41 PM
jdphog's Avatar
jdphog
Stage I
Unhappy Speedometer Gone Crazy 2013 Roadking
Bike was running great when I turned it off last night. Went to go on a ride first thing in the morning great weather and the speedometer started going crazy. It was showing when you were at 30MPH the speedometer was displaying 80MPH. I kept going this way until it would just peg it self so when you were doing about 50MPH the speedo was buried past 120MPH and then the engine would lose power like there was a speed limiter on the bike.
Any suggestions on what could be the issue - could it be a bad vehicle speed sensor?
Old Jul 23, 2018 | 08:46 AM
Zanthamos's Avatar
Zanthamos
I would check vss first as it is most likely tet culprit.
Old Jul 23, 2018 | 09:52 AM
jeff53404's Avatar
jeff53404
This was on my last cycle (2009 Trike). wasn't the speed sensor, just a bad boom software (NaN is not a number).
Old Jul 23, 2018 | 10:09 PM
Ivan Fernandes's Avatar
Ivan Fernandes
Stage I
I'm having the exact same issue as you. I was actually going to post my issue when I came across yours.
Symptoms:
1. Much higher speeds displayed on speedometer. (ie: parking lot speed would display 100 km/h or higher, etc).
2. Self-cancelling signals stopped working.
3. Odometer seems to increase faster (although it might just be my imagination since I haven't tested on a known distance).
4. No codes.
Unsuccessful Repair:
1. Replaced VSS. Still experiencing exact same issues. Old VSS was clean (zero shavings) upon removal.
I'm at a loss of what part to suspect next. I cleaned VSS connector pins, and speedometer connector pins. Still same result.
Any ideas? ECM?
Old Jul 24, 2018 | 08:15 AM
Zanthamos's Avatar
Zanthamos
Speedo would be the only other option.
Rathgar
Aug 24, 2019 06:36 PM
Renegade946
Apr 20, 2018 04:18 PM
HeadoftheBeast
Electrical/Lighting/Alarm
Aug 13, 2015 04:26 AM
tcfamy
Jul 14, 2007 07:15 PM
Jkid
May 3, 2007 05:02 PM
