Electrical issues
Old Jul 22, 2018 | 04:36 AM
Wags69's Avatar
Wags69
6th Gear
Default Electrical issues
I have a 98 Sporty 1200. Went and changed the bars, and a few other things. Everything was working until I changed the worn riser bushing out.
Now I have no horn, turn sigs, brake lights, and speedo/odo not lighting up/displaying. I have checked grounds, but I am at a loss as to where to go next.
Old Jul 22, 2018 | 05:42 AM
Jackie Paper's Avatar
Jackie Paper
Pull it back apart and see what you skinned off the insulation. Read what you have done couple times a week.
Do a search and take your choice. Probably a fuse but good chance grounded wires are causing it.
Lot of Harley's are turned into junk this way. Be careful.
Old Jul 22, 2018 | 08:46 AM
14GuineaPig's Avatar
14GuineaPig
Check the Accessory fuse. Everything you mentioned is powered thru that fuse.
Old Jul 23, 2018 | 08:15 AM
grbrown's Avatar
grbrown
I agree with the two above. Electrical problems are a by-product of doing any electrical work, especially when in involves handlebars! It is very easy to trap a wire when tightening up the handlebar switch housings, but even easier to damage wires when extending them, especially if doing internal wiring. Carefully and thoroughly retrace your steps.
Old Aug 26, 2019 | 11:22 AM
davistrembley's Avatar
davistrembley
Stage I
Electrical problems can't be resolved easily, so without the help of any electrician or mechanic it's possible to fix the problem.
Old Aug 26, 2019 | 12:09 PM
nevil's Avatar
nevil
That's a lot of confusion wrapped up in a single sentence. Are you running for office?
Old Aug 26, 2019 | 03:57 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Nonsense
Old Aug 26, 2019 | 05:03 PM
RANGER73's Avatar
RANGER73
Electrical problems can't be resolved easily, so without the help of an electrician or mechanic it's impossible to fix the problem.
Fixed it for you. But it's not an accurate statement
Old Aug 26, 2019 | 05:14 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Deleted
sportstersparky
Electrical/Lighting/Alarm
May 31, 2016 12:17 PM
cromagnon
Aug 4, 2011 06:26 PM
1sikbob
Jul 17, 2010 02:57 PM
kg4epz
Oct 31, 2008 09:22 PM
Sharknose
Jun 5, 2007 06:28 PM
