Electrical Issues
Old Aug 25, 2018 | 01:16 PM
Clark1417's Avatar
Clark1417
1st Gear
Exclamation Electrical Issues
I have a 2016 Ultra Limited. I dumped the bike on a stone covered road. Since it went down I keep blowing the 5 amp battery fuse with the ignition off. Any help would be appreciated.
Old Aug 25, 2018 | 01:29 PM
Jackie Paper's Avatar
Jackie Paper
Any obvious damage to the bike? Is that the power for the alarm?
Old Aug 25, 2018 | 05:28 PM
Vernal's Avatar
Vernal
Hope you're OK.
Battery fuse power goes to both grips R/O wire. If it hit hard on a grip I guess you could pull the fairing and unplug the connector to see if that's the problem. It powers the siren, ECM, Volt Meter and Fuel gauge.
Old Aug 27, 2018 | 02:46 PM
Zanthamos's Avatar
Zanthamos
Check the fenders, the fender tip lights are powered off of the O/W wire as well.
Old Aug 27, 2018 | 04:13 PM
Vernal's Avatar
Vernal
Fender tip is powered off the BE wire from the BCM. It does change color at the Fender tip connector.
Old Aug 28, 2018 | 10:28 AM
Zanthamos's Avatar
Zanthamos
Ok, that's a change. Thanks for the correction.
Old Aug 28, 2018 | 01:33 PM
Vernal's Avatar
Vernal
It's hard to keep up with all the changes. I hope the OP comes back to let us know what the problem was
bobbyjoes
Audio Systems
Mar 15, 2017 08:06 AM
roadglider1
2014-2024 Touring Models
Jun 6, 2015 09:07 AM
mobyjohnson
Sep 20, 2012 07:25 PM
scottdoege
Mar 16, 2009 06:47 PM
DomC
Apr 26, 2007 06:25 PM
