Electrical problems
Old Sep 30, 2018 | 02:12 AM
LowBudgetBiker's Avatar
LowBudgetBiker
Stage IV
Default Electrical problems
I have an 06 Sportster 883 and the other day I gave it a bath. Now my speedo isn't working, it's not tracking my mileage, and my blinkers don't turn off automatically after making a turn. Anyone have an idea what the problem is or where I might start looking?
Old Sep 30, 2018 | 03:15 AM
mmesa005's Avatar
mmesa005
Check your fuse box for water. Pull each fuse 1x1. https://www.hdforums.com/how-tos/a/h...rmation-412794
Old Oct 1, 2018 | 02:49 PM
Zanthamos's Avatar
Zanthamos
Check the VSS connector on the transmission, the connector commonly gets water trapped in it, disconnect it then clear it out with air compressor hose and then put some dielectric grease in there before you reconnect it.
Old Oct 3, 2018 | 11:58 PM
LowBudgetBiker
Stage IV
Before I had a chance to read your reply I searched youtube and found a video about the vss. He recommended replacing it, but I could see that water had got trapped in there and caused some corrosion. I cleaned it out with alcohol and a toothbrush. Works again. Thanks for the info though! I'll have to go back now and put some of that grease in there.
Old Oct 4, 2018 | 12:53 AM
mmesa005's Avatar
mmesa005
Glad you solved the problem and updated the post!
Old Oct 5, 2018 | 06:07 AM
assiniboine's Avatar
assiniboine
Word to the wise? Don't pressure wash your ride!
Hellrazor
May 5, 2021 09:22 AM
Shane-Chrissy Rose
Jun 19, 2017 04:34 AM
ChefE
May 6, 2008 11:17 PM
lightmaker
Apr 15, 2008 09:00 PM
TJ461vs
May 20, 2006 06:49 PM
