Ok, I brought my self a new 17 1200 Custom 20 months ago and Im finding that the battery that came with the bike is now requiring charging before a days ride. Now once out in the road it will start at a quick push on the button , But if I leave the bike sit for a day or 2, starting is a different story.
Has HD had issues with bad batterys or should I be looking elsewhere before I go back to the dealer.
Get a new battery. Whoever gives you the best deal for a correct battery. Some last longer. Some don't. Nothing wrong with Harley but you probably pay a premium.
My original battery lasted 4 years. I replaced it with a POWER SOURCE battery I got from an aftermarket store. That one lasted 8 years. Since the aftermarket battery lasted twice as long and cost 1/2 as much as a replacement from Harley does that mean it is 4 times better?
Seriously, as RIPSAW indicated " Whoever gives you the best deal for a correct battery".
I’d suggest some diagnostics first:
- load test on the battery
- when the battery is fully charged, disconnect the negative post on the baterry, then let the bike sit for a few days. If the battery still drains down...it’s the battery. If the battery does not drain down, then you have some kind of parasitic load that is draining it.
Sounds like your bike is still under the the MoCo's factory warranty if its under 24 months. Your battery should be covered. BUT, you'll have to bring the WHOLE bike and battery installed to confirm that the battery is failing to hold a change, or an electrical issue that's causing the draw.
I made this mistake by taking the battery out myself and bring it to Modesto HD. The parts manager was a total D**K about the whole thing, although his rational did make sense! However, I'm pretty mechanically inclined, and knew my battery was gone because I always had it on a battery tender. AND, wouldn't take a charge on my regular battery charger either....
Even though this wasn't my first brand new bike I've bought from Modersto HD (first being my '12 FLTRX) they didn't extend ANY courtesy. I got so turned off by his attitude, I just bought a HD battery from them and reinstalled it myself.
I also have bad history/experiences with they service department too, and didn't care for them to hack up my bike with a simple battery install either...just saying.
My last two came from Walmart at apx 2/3 less then the MotherShip. They lasted around 4 years. Harley's lasted 5 years.
I couldn't agree more with you more... Typically the HD batteries have lasted 4 to 5 years for me too on my other bikes. But, I'm thinking HD changed vendors for their batteries in the last couple of years. I've gone through two batteries on my '14 now?
Id suggest some diagnostics first:
- when the battery is fully charged, disconnect the negative post on the baterry, then let the bike sit for a few days. If the battery still drains down...its the battery. If the battery does not drain down, then you have some kind of parasitic load that is draining it.
Yep, took your advice and its the battery. Put it on the Harley battery tender over the weekend and it had a full ( green ) light on it for over 12 hours. I then let the battery sit all Saturday night to Sunday morning, reconnected the terminals, it did start but pretty much the Speedo display went blank , starter groaned and lumped the motor over real slow but enough for it to catch and fire.
Im calling the dealer tomorrow about a replacement.
Ok what Im looking for is something above the stock 240 cca rating but not finding anything close to that on line.
Yeah having the Hebei jeebies about the stealers cocking up somethingnin my bike doing a batt check swap out.
