Engine light code?
Old Jun 15, 2019 | 04:07 PM
Riffraff123's Avatar
Riffraff123
Default Engine light code?
2000 Heritage engine light came on 2x while highway riding. Went off after about 2-3 minutes while riding. Engine runs well, no driveability issues. Engine light continues to give the "historical code" indicator. See attached video. To me it looks like code 12 which FSM says would be MAP sensor but it's a carb bike. What do you think? Speedo code check all shows "clr" CAL 03.
Thanks in advance.
Old Jun 18, 2019 | 09:05 AM
skinman13's Avatar
skinman13
Your bike should have a MAP sensor on the intake. Pn 32316-99. Cost around $40. Check and clean the connector and if that doesn't clear the code, replace it.
Old Jun 18, 2019 | 08:30 PM
Riffraff123
Carb bike. No map sensor, no O2 sensors.
Old Apr 2, 2020 | 06:53 PM
Riffraff123
You were right, I was wrong. It does have a MAP sensor and it WAS bad. Thanks for the help.
Old Apr 2, 2020 | 07:49 PM
Ed Ramberger's Avatar
Ed Ramberger
The MAP sensor replaces the VOES of days gone by and allows ignition modules with much far better timing tables.
Gatorok
2014-2024 Touring Models
25
Oct 13, 2016 12:01 AM
emperor wurm
Oct 21, 2015 01:05 PM
Redbeard69
EVO
21
Sep 6, 2013 10:11 PM
fireleu6169
Feb 10, 2012 03:23 PM
lkman111
Aug 1, 2008 09:45 PM
