Main Fuse
Old Jul 5, 2019 | 04:06 PM
Pete Herrera's Avatar
Pete Herrera
Stage III
Unhappy Main Fuse
I attempted to jump-start my 2000 Roadking FHLRI and apparently blew the main fuse. I have been unable to locate the main fuse to replace it... HELP !!!
Old Jul 5, 2019 | 04:13 PM
mmesa005's Avatar
mmesa005
https://www.hdforums.com/how-tos/a/h...diagram-413981
Old Jul 5, 2019 | 04:25 PM
mmesa005's Avatar
mmesa005
Here is your Main Circuit Breaker location
Old Jul 5, 2019 | 07:31 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Deleted
Old Jul 5, 2019 | 07:47 PM
Pete Herrera
Stage III
Default Main Fuse
Thanks for the info, I already replaced the circuit breaker but I still have no juice when I turn on the ignition switch. I was told the main fuse on my m/c is located under the battery box but have no been unable to locate it.
Old Jul 5, 2019 | 08:01 PM
Rustyg500's Avatar
Rustyg500
The 40 amp circuit breaker in the diagram takes the place of a main fuse.
Old Jul 5, 2019 | 09:26 PM
mmesa005's Avatar
mmesa005
Suggest you have the battery tested and check your battery cables end to end for condition.
Old Jul 20, 2019 | 03:33 PM
Pete Herrera
Stage III
After testing the newly installed circuit breaker I found out it was defective so I installed another one and by bike is fixed!!! Thank you for your assistance !!!
Old Jul 21, 2019 | 08:42 AM
skinman13's Avatar
skinman13
Warning...Circuit breakers usually don't just "go bad." Look it and the wiring to and from it over real good and see if there are any indications of overheating, even slight. While it is very possible that the circuit breaker failed mechanically, I would not automatically assume that is what caused it to fail. If it is carrying a load that is close to it's trip point, it will eventually weaken and fail and you should be able to see indications of overheating.
mnewton338
Apr 3, 2019 07:14 PM
Michael R Moore
Electrical/Lighting/Alarm
Jan 23, 2019 12:21 PM
iammulva
Jan 7, 2014 03:01 PM
FtpdMoose
Nov 24, 2010 04:13 AM
TimFL
Dec 25, 2006 08:44 PM
