Custom Dynamics Probeam (Rear)
Old Aug 15, 2019 | 06:38 PM
Sporket's Avatar
Sporket
6th Gear
Default Custom Dynamics Probeam (Rear)
I have previously installed the halo turn signals on my 2012 SG. Of course I had to install the CD Load Equalizer for them to function properly (done many years ago). So today I received the Probeam rear brake lights/turn signals installed them and upon idle the lights remain only in brake mode. So no function of running or turn signals. Will I have to install another load equalizer for the rear lights as well? I was running cheaper LED's on the rear....
Old Aug 28, 2019 | 06:47 AM
enodrano's Avatar
enodrano
1 load equalizer will be should be fine. On my 2011 Street Bob, under the seat, my CD Load Equalizer interfaces with the brake switch harness. There is one for the front harness and one for the back, and the connectors are identical. I originally plugged the Load Equalizer into the wrong harness (front). Once I moved it to the back, hyper-flashing stopped.
Make sure the bulbs are the 1157 version. Also the 1157 barrel pins should be staggered to prevent incorrect installation, but with enough force you could accidentally reverse the connection.
Old Aug 28, 2019 | 07:54 AM
KYRGultra's Avatar
KYRGultra
Call CD customer service. They are very helpful folks.
Old Aug 28, 2019 | 04:30 PM
Custom Dynamics's Avatar
Custom Dynamics
Former Sponsor
Hi @Sporket , it sounds like the turn signals could be installed backward. Please give us a call between 8:30 AM and 5:30 PM Eastern Standard Time (we are off for an hour between noon and 1 PM) and we'd be glad to help get everything working correctly. 800-382-1388.
Rjmbass76
Electrical/Lighting/Alarm
Jan 18, 2019 04:11 PM
TexFF
Nov 15, 2014 11:20 PM
ghostrider69
Oct 27, 2014 07:32 AM
a21m
Sep 1, 2014 08:45 PM
Weatheredge
May 30, 2011 07:29 AM
