Electrical glitch
Old Aug 18, 2019 | 03:04 PM
Brett Harrigan's Avatar
Brett Harrigan
Stage I
Default Electrical glitch
I have a 1999 fxd superglide, 88 ci 1450 cc. When vibration picks up top of second gear speedometer goes to 0, odometer goes blank and turn signals wont blink, pull in clutch vibration drops and everything starts working again. Looked at frame grounds redid some wires cant seem to find the issue. If anyone could help I need it and appreciate it. Thanks in advance.
Brett Harrigan.
Old Aug 18, 2019 | 03:46 PM
Bass Player's Avatar
Bass Player
Short, loose / broken wire someplace. These things can be a PIA! You said you re-did some wiring. What was last thing done before this started happening? What did you re-wire if anything. Get in your service manual and see what's common. My guess is a wire job that's been added or changed?
Old Aug 19, 2019 | 08:08 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Check the connectors, look for any pins that may be backed out.
budlight2256
Nov 24, 2018 07:13 AM
Mullenix53
Apr 20, 2013 10:36 AM
Smithdogs
Mar 2, 2013 07:29 PM
sturmme
Jun 26, 2011 10:38 AM
hawg68
Jun 18, 2007 01:23 PM
