Voltage Regulator / Rectifier failure
Old Aug 19, 2019 | 08:48 AM
Sixfinger's Avatar
Sixfinger
6th Gear
Default Voltage Regulator / Rectifier failure
Hello everyone,
So, I own a Sportster Iron 883 MY2016.
Few days ago I got a red battery light and after a while the bike died.
Went to the dealer and said it was the Rectifier (voltage regulator) and needed replacement.
Any input on what causes this device to go bad? Has anyone had the same issue?
Should I be wary on a thing after the replacement?
Another detail I would like to share is that I had a fuel management device installed a couple of days before that. Could this have caused the failure of the voltage regulator?
Any input is appreciated!
Thank you in advance!
Cheers!
Old Aug 19, 2019 | 08:59 PM
bustert's Avatar
bustert
sometimes doodoo just happens.
you need to look at the total load the machine is running and allow at least 20% fudge factor to ensure proper charging.
the machine runs off the regulator when the battery is fully charged. things that can effect the unit are bad grounds, bad wiring and a iffy battery. basically anything that offers high resistance to the regulator as the unit will ramp up to over come it.
Old Aug 19, 2019 | 09:01 PM
TriGeezer's Avatar
TriGeezer
Crap happens. It’s an electronic device exposed to heat, cold, wet, vibration. Sometimes they fail.
Arjeje
General Topics/Tech Tips
Feb 18, 2016 10:21 AM
SeismicAssault
Jun 11, 2013 10:14 PM
Michele Gordon-Huffman
Sep 6, 2012 10:58 PM
nichols292
May 1, 2012 03:45 PM
icehead2
Jul 27, 2010 03:59 PM
